For Sale Studio summing amp, line amp BFE DV1175
Things you have for sale.
Hi folks,
here for sale a summing amp also to use as line amp with two channels. Signal up to +22dBu. Balanced groundfree in/out with high quality studio transformers.
Can be used as summing amp in a mixer with an input rail or line amp with up to 20dB gain. For example also for long signal distances of up to 900ft / 300m for FOH use.
Incl. schematic and pinout.
Asked price is 75,- $ + shipping. Serveral available......(The cost of one transformer btw is about 110,- $), questions are welcome.....
regards
HP
Hi again,
there are not only the BFE 1175 amps.....I have also Lawo DV975, Delta System V1072D and others,....all with similar data and lots of relais cards for audio crossbars or prehear and monitoring matrix's. Very easy to build a switcher.
Will be happy to answer your questions about the usage in any system.
regards
HP
