Crossover
Hello all.
I was hoping to get your professional help in understanding the impedence and phase readings of my
very first crossover made in Xsim.
Any significant faults in the crossover design?
How does impedence and phase look?
Thank you very kindly in advance
I don't see any problem with the results, but I would change the tweeter padding a little. Take some of the 6.8 ohm resistance, and place it after the x-over. Try 3 ohms before, and 3 ohms after. The other components will need to change too. Later in the sim, you have the option of changing either resistor, for slightly different effects.
I would try a larger coil on the woofer for BSC.
