Found a couple of Mission 77 bookshelf speakers in good condition. Not tested yet. Just wondering if they are worth keeping or modding. Thinking of using them in the bedroom or as workbench speakers. Did the usual search online and there are no reviews, so I'm assuming that they are not really considered any good. Am I wrong? Thanks.
These are sealed box, shelf or stand mount speakers manufactured around 1990. https://www.retrotronics.co.nz/detail&id=1583
They'd suit a small room and would benefit from being positioned close to the rear wall for bass reinforcement.
I think they would give sterling service as workbench speakers.
And let's consider that Mission don't tend to make speakers that are "not really considered any good".
Specifications:
75 watts into 8 ohms – recommended amplifier 25-40 W
Dimensions: 37 cm H / 22 cm W / 25.5 cm D
Weight: 5.2 kg each
Specifications:
Weight: 5.2 kg each
I've been reading this thread
The model 77 appears to use the same bass driver (Mission 70 S) and a VIFA D19 TD-5 tweeter (photo attached). Maybe I can make some improvements by recapping the crossover ( 5.7uF 50V and 10uF 50V non polarized as marked N-P). Any suggestions for improvements are welcome. Thanks.
Hello, looking for advice on my next set of speakers.
System electronics is a NAD 7125 receiver (similar amp to the famous NAD 3020), vintage restored Sony CDP-101 CD player, AKAI GX-625 reel to reel and Pioneer PL12D turntable - some middle of the road classic 80's hi-fi, listening to old rock, Dire Straights, Leonard Cohen etc.
The sound is "satisfactory" to my 60 year old ears through a pair of well travelled Mission model 70 (original, not the MK II) speakers, now maybe 40 years old. Believing the speakers are the weak link, and pondering if to update & replace them. I am from...
- floridaclear
- Forum: Multi-Way
The NP electrolytic capacitors may or may not still be in spec after 35 or so years, but it would be an easy matter to replace them.
Substituting fresh NP electrolytic capacitors will ensure that (a) the original voicing of the speaker will be restored and (b) the replacement capacitors will fit comfortably into the spaces on the crossover board.
MKP Polypropylene film capacitors of the required values would be much larger than the electrolytics and would alter the voicing in a way that you may or may not prefer. It's up to you whether or not you want to experiment in this direction.
Today's standard values would be 5.6 uf and 10 uF, and I'd be happy with these Mundorfs from Wilmslow Audio:
https://wilmslowaudio.co.uk/mundorf-electrolytic-ecap-capacitors/56-fd-ecap70-electrolytic-capacitor
https://wilmslowaudio.co.uk/mundorf...pacitors/10-fd-ecap100-electrolytic-capacitor
- Mission 77 bookshelf speakers-Worth keeping/modding?
