Hello from Provins in France, I am passionate about audio amplifiers and preamplifiers, particulary ARTEC french products that are no longer build and distribued today. Actually, i look for restore an old ARP300SE, an hi-end hybrid tube + MOSFET audio amplifier that sound very very well ! And a lot of others projects like, in a short time, the creation of a very high quality 12VDC/5A power supply to another audio application. First reasons that make i join your community today ! Best regards
Hi and welcome.
The amplifier you have seems like it was a fairly expensive piece of kit, hopefully well made and reasonably easy to therefore hopefully easy to repair. Do you have schematics to work from?
Hello Raymond! Thank you much.
Yes, it is a beautiful amplifier with only a few units in existence. It has a beautiful construction with-quality components, where I can easily read the references to replace parts. However, today I believe the problem is soldering troubles. Nevertheless, I can consult the designer if there are any questions. I hope I can successfully repair it.
