NAD T748 input problem
Hello.
NAD T748 V1
Works fine, just one problem.
Analog Source one......no sound.
All auther sources works fine but the sound appears only after 10 seconds
That is, if I select an input, it appears on the display but the sound will only appear after 10 seconds. There is never any sound at analog input number 1.
Factory reset doesn't help.
Last firmware is installed.
Service manual
https://acrobat.adobe.com/id/urn:aaid:sc:EU:7d422752-fb6b-45b5-aaa3-3ae30999865c
Voltages On IC301
Pin 30.....+7v....ok
Pin 52......-7v ....ok
With oscilloscope on IC301
1khz square
Input analog 1
Pin 62......ok
Pin 63.......ok
Outputs Front L & R
Pin 21..... nothing
Pin 23....... nothing
Bad IC301 or other people?
