Nippon Chemi-Con capacitor
Just bought some brand new Nippon Chemi-Con electrolytic capacitors from Mouser. Is a KMZ series, 470uF 420V.
I am surprised that all the 4 pcs have value 412....414uF. So is below with 13% from nominal value. I agree there is on +/-20% limit, but being brand new, I expected to be closer to the nominal. I tried to apply voltage for 24 hours and still the same, no change. I measured it with a RLC meter.
The date code is 1NT058. After some research, I found that the first digit represents the year of manufacturing, so is 2001, 2011, 2021....??
Any comment on this?
Welcome to the modern world, this is not just electrolytics, plastic film caps also suffer from this nowadays, my guess is that process technology have made it possible to control the capacitance very precisely so always being in the low end of the tolerance span saves a couple of turns of foil for each capacitor made, since the large manufacturers make millions of capacitors each year this is a significant saving for them.
Electrolytic capacitors used to be -20/+50% in the past and in reality they were practically always higher in value. In fact it was suspicious when they were spot on or in the -20% region.
So that stays in the mind of most just like tantalum caps always being unreliable, SMD being inferior to TH, LM317/LM337 being best standard regulators etc.
Maybe they are older than expected. In my cap collection there are a number of older electrolytic capacitors from various well-known manufacturers, all from official distributors, which have all lost capacity over the years (10 years and more).
I'm impressed all four are at -12% (412uF). Would you feel better if two were +12% (526uF)? If you checked enough of them, a statistician could tell if they sorted out the precise ones for their Audio-File Label caps.
In the Tokyo subway you can sometimes see Nichicon ads...
I recall (circa 1970 and the cap may have been 20+ years old back then) seeing an electrolytic with tolerance +80/-20. Manufacturing tolerances apparently have gotten better since then.
This happens (or so I've heard) with all components. One might order a bunch of 2% resistors, maybe expect them to be equally distributed from -2% to +2%, but they may be missing all values between -1% and +1%, as they may be measured and higher precision removed and sold for a higher price. The guarantee is that they're within the tolerance limits, it says nothing about what the distribution of values in between might be.
For power supplies worst case calculating is standard.
For ALL designs, using the worst-case values on the data sheet is the only way to design. Anything else is relying on parts being BETTER than what the data sheet guarantees. I saw Bob Pease say this about 24 years ago - I almost couldn't believe it, it seemed obvious to me, but clearly many younger engineers don't know that only the Min and/or Max datasheet values are guaranteed.
