bhjazz's BA2018 Ground Noise Problems
Joined 2006
My initial posts are in the Wayne's BA 2018 thread starting on page 224 here: https://www.diyaudio.com/community/threads/waynes-ba-2018-linestage.329240/page-224
For the test table below, The VRDN units pictured will be named, Chuck, Alfred 1, 2 and 3 from the bottom up.
The bottom unit is closest to the front panel.
1 and 2 will power BA2018 channels right and left, respectively.
3 will power an Academy Audio ISS and MCU.
1 and 2 are set at +/-18V, 3 is set at +/-15V.
For now, the output transformers are disconnected.
TestResultsNotes
Add jumper for VRDN Denoizer circuitfailnoise did not change
Include ISS system / exclude ISS systemfailnoise did not change
Check that the screws attaching the PCBs to the chassis are not shorting the Ground on the PCB to chassis.failno screws appear to be shorting to ground.
removing the 3rd set of power wires from the Antek (going to the 15 VDC board) then checking the two BA2018s (CraigI59)failnoise still apparent in both channels
disconnect the wires from the VRDN to chassis (andynor) linkfail
short BA2018 inputspasshelped a lot for single channel test
run a short fat wire between those two grounds. From the center of that short fat wire, connect the rest of the ground wires from the loads.. "T" style. (william2001)pass-ishTested a modified version of this by daisy-chaining ground connections to each other, then connecting the last VRDN to star ground.
gather those ground wires into one connection point, instead of leaving two inches between them as loop area. (andynor)pass-ishTested connecting each VRDN to the next VRDN, then connecting VRDN 3 to star ground. Knocked the noise down a huge amount. Still there, but possibly getting some open loop noise from the two longer VRDN-to-Star-Ground wires which are hanging around.
Will remove those and test again, but possibly on the right track.
Left channel run alone. Quiet or noisy? (benmah)passquiet
Left channel with right channel power supply, run alone. Quiet or noisy? (benmah)passquiet
add 0.1uF cap in parallel to 5 Ohm resistor (BH)
If lifting the chassis connections by and itself solves it, use a GLB. A simple resistor may not solve it. (andynor)
connect the two BA2018 halves’ ground sockets (andynor)
Reactions: andynor
LOL. Awesome. Before I can even move data over. :rofl: THIS PLACE ROCKS!
btw nothing was accomplished yesterday. Early winter yard work...brrr...
<edit> All tests mentioned in the BA2018 thread are now here for reference.
Channels running alone and with power supplies switched around were all quiet. That is a good thing.
But the channels were noisy when both were running at the same time. The issue may be with the preamp or it may be with the headphone amplifier used for testing.
The preamp is not quite dual mono as the power transformer is shared. For completeness, please show connection details from IEC input to power supply boards.
During tests, a headphone amplifier was used. Try a different amplifier (power amplifier) and test the preamp with both channels running. Short the preamp inputs for the test.
Reactions: andynor
Ben, I appreciate your urging to try anything other than my headphone amplifiers, because I took the chassis down to the bonus room where the rest of the gear is. Currently for amplifiers I have a pair of modded ACA 1.8. The 3 VRDNs are daisy-chain connected to each other at their grounds, and the last one in line, #3, is connected to star ground. Result? Total silence. So a few changes from everyone's head and things are pretty darn good.
The next phase, then, is to connect the ISS board to the BA2018 inputs.
Thanks for all the help so far, everyone!
bhjazz, I just remembered one interesting case. Sorce and headphone amp was powered from different outlets. And electrical outlets had a different ground potential. Noise was persistent until both was connected to the same electrical outlet.
Good idea, RainfallSky, but I was careful to connect both to the same outlet.
The interaction between the two is still puzzling. This is my go to headphone amp, a CK2III designed by Ti Kan at AMB Laboratories and this is the first time it has given me problems when connecting to anything. 😳
Cheers!
You guys are awesome. Thanks! I'll read up. 🙂
If my build is quiet without a ground breaker, I leave it out. It is the safest.
I would tend to agree with this. Although with my current system (using the passive pre section of a Mytek DAC) I ran into an issue with it and a phono pre just last year, long after I had begun to use it. Life is strange.
