connector ID help
on an Onkyo Dx-1400, and I am sure others, there are two connectors for wires to the CD mechanism (actually 4) that are 8 and 9 pins and go from the board to the laser assembly. Does anyone know exactly what these connectors are so that I can order a new plug. single row, 2mm pitch, pins on the board and crimped sockets on the wire end.
Many thanks. There are quite a number of connectors with similar configurations. I had no idea whether JST, Molex, or something else. The JST looks perfect. I munched one of the crimp on connectors and thought a whole new plug with wires was much better. Digikey has wires with crimped on connectors. Suppose I could just replace the munched one. Thanks again. Yay!!! Deoxit and transistor tester showed up today.
