Yup, living cells are somewhat capacitive as cell membranes are insulating - hence the FR. The conductivity is quite good though as vegetables have vessels for carrying nutrients around, these are effectively wires as they contain fairly conductive liquid (i.e. salts).
Distortion is very good - I suspect if you used higher signal levels you'd hit a point where electrochemical potentials were exceeded and distortion would start to rise up.
https://en.wikipedia.org/wiki/Glowing_pickle_demonstration
- Design & Build
- Equipment & Tools
- When you need to join two male connectors… organic audiophile carrots!
