https://www.audioholics.com/amplifier-reviews/cherry-megaschino-mk2/#toc-h2-0
Can this amplifier be repaired by a competent amplifier repairman? For example, if the caps began to degrade, or the power supply conks out...etc.
I note that the amp was built 4-5 years ago and by a one-man shop. Unfortunately that young man has passed away. Hence, there are no schematics that i can find for replacement parts numbers/parameters and the company that produced the amp was shut down.
Thank you
Thank you
