I am a beginner and i need help with my speaker build
I have started to build my portable speaker and I run into a problem. The crossover that I build does not work properly .Can someone help me
With the best regard Casian ( I am a beginner and I am new to the forum so please understand my shortcomings )
Your schematic shows 6 coils, 6 caps and no resistors.
Your board appears to have 3 coils, 3 caps and no resistors.
I see what appears to be huge value caps 12,000 and 33,000 µfd.
This went wrong before the parts even arrived.
It looks like you are ready to start again with the correct parts and following the schematic.
Did the drawing come from the Omni crossover design application?
I hope the members are able to get you turned around on this one.
There will likely be many questions coming your way.
I have moved this over to Multiway forum so it gets more attention.
With the best regard Casian ( I am a beginner and I am new to the forum so please understand my shortcomings )View attachment 1385130View attachment 1385131View attachment 1385132
As Cal mentioned, those caps are wrong value. But not only that, they are wrong type.
The electrolytic caps you installed are used in power supplies to smooth out dc voltages. They are not suitable for ac signal (music).
For crossovers typically bipolar electrolytic capacitors are used, for bigger values. For smaller values, like in tweeter section, mp caps are used.
Reactions: Audio>X and AllenB
The calculator for C4 and C5 shows 11.xxx uF and 34.xxx uF values.
The period "." is used to indicate decimal point, not a separation of 1000s. This is common notation in US and England e.g. which is contradictory to many European countries. I suspect that may be why the photo shows 12000 uF and 33000 uF caps.
Find some suitable caps with the correct values.
Also, don't use electrolytic caps, as noted by @adason.
