EL84SE with local NFB?
Hi, mainly for curiosity i would like to learn on an EL84SE amp with local NFB.
Imagine a standard EL84SE, pentode mode, kathode bias. NFB is usually being appplied from the 8 or 16 Ohms tap of the OT to the cathode of the stage in front of the EL84.
And what if the application needs a volume pot ore some kind of tonestack just in front of the EL84?
Which means that there is no NFB of this kind possible in a meaningful way - it would depend on the position of the vol pot.
So - applying NFB directly to, say, the cathode of the EL84? Which would, of course require that the cathode condensor of the EL84 be omitted.
That would lead to
a) current NFB due to the missing cathode condensor
b) NFB including also the transformer.
has someone also done this? How would, for example, the stability of the bias point be affected?
You would have to flip the usual polarity of the primary winding to get the correct polarity for feedback to the cathode.
The DC bias won't be affected at all, since there is no nfb at DC with transformer coupling.
The schematic in post #3 shows classic CFB, cathode feedback. I use it in several of my DIY amps and it works well. Yes, there will be a little bit of DC across the speaker terminals but the DCR of the transformer winding is just a fraction of that of the speaker so it's usually 40mV or something like that.
The amount of feedback depends on the output stage gain and the turns ratio of the transformer, usually 3-6dB.
Reactions: DrowningNotWaving
I treid it recently as an experiment:
There ist a world outside guitars. basses, keyboards, hifi...
The amp i woult like to try it first is actually a tiny bass amp (a heavily modded Epiphone Valve Junior, ECC83+EL84). That one will profit from NFB including the OT (something better than the original one) because it will also linearize the latter. It actuaslly has NFB added, to the cathode resistor of the 2nd triode. Meanwhile i need the cathode for further sound modification, and i would like to have a vol pot aver the 2nd triode as well. And of course i would like to keep the NFB.
But again, i would first like to improve my knowledege, for further non-guitar amp projects.
BTW: what exactly is "Schade" NFB? Just NFB from the anode to the input grid?
