I wonder if it will still do ‘TS’ parameters (small signal) relevant to simulation software or if it’s ?
Would really need to stretch it to 300VA to measure some parameters at Xmax. Would be way to cool to have large signal behavior measurement in ones palm/lap.
You can do large signal parameter measurement at whatever power levels you want right now for free with REW.
@hurrication For electrical, you need gear for that. That's the issue. The hardware.
@Booger weldz Not enough for "full" box testing, and while I'm not doing that yet, I might need to learn what to do with it. 🤭
It’s purported to do Klippel-like BL(x), Kms(x) and Le(x) curves
Yes, and? My amp doing over 500Vpp to the speaker is gonna do what to line in input? I am not talking about SPL. For that I have a dedicated soundcard with phantom power and a mic. I am talking about large signal electrical parameters. As mentioned, Kmsx and Blx, Re, Impedance curve and such..
bl/kms are nonlinear distortion parameters, you aren't going to get any of those without a klippel.
Large signal parameters are just normal t/s parameters only at a higher voltage. The word "amplifier" in my last comment is a link to the schematic on how you hook up your amplifier to your PC so that REW can measure large signal parameters at higher voltage levels.
One can substitute certain measurements by measuring steps instead of seeeps. A sacrifice worth doing. Thank you, I will look into the REW.
You listen to 500Vpp? Good for you. Two resistors can make it to 0.1x, 0.01x or 0.001x, whatever you want. Just two resistors on the input of soundcard. But i am sure you will have some smartypants response to simple solution.
Well! 😂 I haven't try yet, I might miss something, but on a bridged amplifier (or with lifted ground/indepebdent GND) you don't want to do that to the input device.
I don't listen to 500VPP, I'd like to measure.
I reported on this back in August in various forms. There will be 2 versions, one with a 500W amp, and one with a 1200W amp, IIRC.
I think you'll be surprised what this and the Omnimic 40K are capable of....
There were also mid domes and tweeter domes for the Epique series, both woven carbon fiber.
All of this was seen at the Speaker Design Competition back in August.
- Subwoofers
- New ‘DATS’ from Dayton
