Fir filter/convolution problem Jriver, Rephase& Rew
I have been driving active diy speaker setup:
Source--> Jriver --> convolution, crossovers 6h--> rme ufx--> amplifiers-->speakers
Crossovers are done with rephase and eq with the eq in the rephase
Convolution file is text .cfg form
This setup sounds good to me....
So then i just wanted to see what is the max out of my old Behringer truths b2031a's, so i decided to eq them flat. To get rid of that rising tweeter response. Took measurements with rew and imported them to rephase. Used the same linear phase eq in rephase as always...
Made two channel .cfg convolution file (Behringer left and right)
Imported it Jriver and started playing..
Sounds completely horrible! All the clarity is gone and its like dual mono but much worse. Soundstage gets really narrow to the center/middle of the speakers .
Problem is clearly in the convolution, because i tested it by importing the rew suggested eq correction (Hz,q gain) manually to the Jriver parametric equalizer and clarity came back and equing is working, makes the sound better than the factory set b2031a
Where is the problem?
