Greetings everyone!
I am a new member and I am looking for help. 🙂
I have a helmet bluetooth intercom using the QCC3024 IC, unfortunately the IC got burned due to over charging. Can I just replace the QCC3024 IC and the intercom will work again? Or it needs some sort of programming for it to work?
Thanks in advance.
Thanks in advance.
Welcome to diyAudio 🙂
What you ask is not something I know much about however the data sheet for the chip suggests it is programmable and configurable so I suspect the chip will be pre programmed by the intercom manufacturer.
https://www.qualcomm.com/products/internet-of-things/consumer/audio/qcc30xx-series/qcc3024#Overview
@Mooly
Thank you for warm welcome and fast response.
I guess replacing the IC needs a special flash programmer. Even if I was able to buy IC from Aliexpress, I need to find a way how to program the IC or dump the original program from a working intercom and flash burn it to the new IC.
Maybe an insider from qualcomm who is a member here can read this and add some inputs. 🙂
