This will probably the last chance to get Rudi_ratlos latest iteration of Symasym boards as it will also be one of my last group buys for this. It's a great sounding amp, check on Forums for more information about it.
It's the latest version with 2 pairs of NJW output transistors. houses a speaker protect circuit (that does not have to be populated, but why wouldn't you). Board size is about 215x95mm. The board shares the option to power the front end of the circuit with a dedicated PSU by setting jumpers.
Price will depend highly on several factors as:
I ran it through several well known PCB manufacturers and I came to about 14-15$ for a single board, not including taxes.
Please share your thoughts and interest that way. If enough people are interested, I will quote for the most requested.
#1 DIYAudio Name / Country / Qty of PCBs / Color (Green / Black / Red / something else) / Thickness (1.6 or 2mm) / HASL-Lead free or ENIG
- Number of interested builders
- 1,6 / 2mm PCB
- Min. is HASL-lead free
- PCB color ;-)
You are right. The cap multiplier was on the black boards only. Not last revision. But this isnt going to happen anyway .
- Group Buys
- NJW Symasym - potential GB Interest
