TOP CABS @ Full Range Question
Good day
So a friend gave me some top cab (empty cabinet) so that i can setup, the back plate specs show 4ohm | 1200w MAX power | 3 way system.... The internal crossover thing are burnt out and I cant find full specs for the cabs [ Sound Barrier XPS - 215f ] I took the dual 15"s to repair so i have them working now.... I just dont know the specs on them, I also need to replace the tweeter/ compression driver but not sure which to get in terms of wattage ....
He gave me a pair of audio pipe 1000w 3 way crossover/ Frequency driver and told me to ask around to see how to use them / get proper speakers to go full range setup.... They also have a 4ohm/ 8ohm jumper cable which im not sure which to set them at... Any help here would be greatly appreciated.... I do not mind ditching the old 15s for new so that I know what specs im working with...
