MEH to Replace Mid Tops
Hello,
Last Summer I currently built the following stack.
Mid Top - selenium Pas3Ma1 - x2 HP 326HZ
Kicks - Cubo Kick - x2 HP 120HZ LP 210 HZ
Subs - MHB 46x2 HP 30/40HZ LP 80 HZ
I am looking to replace my Mid Top With a MEH Synergy Horn Type. This Horn will basically remove the needs for my kicks. But I want to keep them.
should I just keep the kicks and double up in that 150-250hz range? Or should I try and structure the MEH with a HP around 300HZ and then the Crossover in the MEH to be higher around the 800/850 Range. I would not have ports if I go with option #2.
from reading If I get rid of the 150-250hz range in the MEH, then the horn does not get any loading? (Is this true?) and the MEH design becomes pointless.
Thoughts?
Thanks,
Cole
You're welcome! Again, remove the mids and it's a tweeter horn, so short of making a huge 350 Hz conical horn, no. An expo would be smaller, but still very large, though in each case its length can be truncated and driven with a suitable wide range prosound mids driver.
