Help me trouble shoot my Inuke6000DSP
Hi all,
I’ve finally managed to test my mini rig today! Results aren’t all that great, and I’m sure I’m being stupid somewhere and would really appreciate some help 🤦🏼‍♂.
The set up I had was a laptop> 3 ring aux> aux to 1/4 inch adaptor into amp> diy speakon cable to speaker
I tried 2 amps-
Crown CE1000 and Berry inuke6000dsp, nothing from the crown, barely audible at max volume from the inuke. Tapping the cable gave much higher volume, more what id expect.
Is it a line level issue? Do I need a pre amp? I’ll be buying an ultradrive to plug the laptop into in due course, but am at a loss as to why it was so quiet.
My other thought was I made crappy 0.19mm2 speakon cables just to test with, maybe it can’t carry enough power but I really doubt it’s causing that bottle neck.
Thanks in advance!
