L-Pad question Re fitting
diyAudio Member
Joined 2007
Anybody here familiar with the Realistic 40-977?
I've just got a pair and I'm wondering how best to mount it in the baffle.
Just eyeballing ; it seems to be a single unit and the rear housing for the resistors seems bigger than the faceplate
I'd normally drill a hole the size of the front level control ring, round the outside of the hole and rear mount the unit.
That said, it looks like the pad might fit through an octagonal shaped hole and still allow the bezel to cover it.
