Can this dome do a 1st order high pass?
Reactions: Arez
The tweeter resonance is not a direct indicator of it's usable range, it's more a rule of thumb. The manufacturer suggests using it above 2k5, which is not a whole multiple of 440.
Regardless, you can do what you want if you're prepared for the consequences. There should be no problem crossing it at a lower frequency, or first order, with reduced output potential.
How is the suspension and motor travel?
Wont have much of a issue crossing to a 5"
Then again after paying 140 dollars for a tweet
Seems like even a 2nd order is non issue
since the coil wont be more than 15 bucks
for much better assurance.
then another cap makes it 3rd order
which is more of a default strategy
if your planning to cross over low.
26mm voice coil is basically ( 1" ) driver
7 to 7.5 cm2 for Sd
Great thing about 5" or smaller mid
Your looking for potential of using smaller tweet ( 3/4")
for even better off axis.
since Sd dips down to 4 cm2
These large chamber Illuminator series
are rather amazing drivers for sure.
Unfortunately feel 1st order be rather
waste of a good driver
But the large chambers helps Fs yes.
Its more if the surround can handle lower frequency content.
So the large chambers can be almost redundant.
If its still a basic 2.5 K tweeter.
As mentioned, agree a listening test is final answer.
1st order works fine actually for many tweeters.
Higher SPL they crackle pretty quickly
Reactions: mayhem13
Yes, for the most part.
And a rather small mounting area as well.
So be great and easy to get tight mounting to the woofer.
Seems to be a thing just from observation
with many scanspeak high frequency drivers.
little bit of wobble n peaks towards the top.
Staring at graphs, many assumptions to be made.
Real world, sound quality is more decay and actual attack
at high spl for a tweeter.
More to do with the dome and surround.
Scan speak prices I assume are higher because they are using
cast aluminum and labor cost not as competitive.
compared to hard plastic frame drivers, with very good surround and cones.
and much more competitive because of labor cost.
Uhm...nobody says it
I guessed that it was rather known ( =shared) that ferrofluid tweeters should be used in this case.
Ok, let me repeat: it is general rule to use tweeters with ferrofluid when using "just a cap".
Why? Ferrofluid stops 'extra motion' at resonance.
