50 years diy, must reduce suite
]Here an idea of shipping cost ,all in US fund : USA = 250gr $14. 500gr $20 1kg $25 2kg $30 (please note only $5. for the last kg); for Canada same but in cdn fund
Europe : 250gr $14. 500gr $25. 1kg $45. (sea mail $24) 2kg $65 (sea mail $34.) over 2kg , sea mail not a choice ! Don't forget I need 100/125gr for shipping box .
23-------------16x MPSU10 4x MPSU56 2x MPSU10 2x MPSU60 9 MPSU 07 all new , genuine from around 1990 $120./33pcs (pic 9118)
24------------8x new Mundorf 47,000 uF 25 volt all tested within 10 % $100. 1kg (9115)
25------------12x new Mundorf 33,000uF 25volt all tested within 2% $120. 800g (9092)
27-----------SALE PENDING SOLD 2x brand new Mundorf 6.8uF 800ac/1200dc supreme silver/gold $160./pair, absolute great sound at reasonnable price ,but long burning time=200hrs.(9114) [B o9]SOLD SALE PENDING[/B]
28------------4x brand new Audyn true copper .33uF 630v $90. per pair and 120gr (9114)
29a------------SOLD 2x new Audyn true copper .1 uF 630v $60./pair 50gr (9114) SOLD
30a--------
-2xSOLD 2x remain used Mundorf 1uF supreme silver/oil 800ac/1200dc $90./pair (wire cut but very usable to solder on board) (9114)
31------------4x used (very little ) Nichicon KG Super Through series ( don't mix with lower price(and sound) similar version but not Super Through $40./pair 500gr (9114)
32----------- 4x new power supply PCB (maintly class A, but fit others) $22./pair (35gr) fit 40mm diam capa (9083)
33------------4x new MrEvil capacitance multiplier power supply PCB (come with 4 LED and J112 transistors each set) $16./2 (9130)
34a------------(12x) only 8 now Elna Audio capa 12,000uF 63v , 35mmdiamX50mm , sell only by 4 unit $35./4 (9122)
35a------------(36x)only24 now Elna 10,000uF 50v (35mmX63mm) ,sell only by 4 unit $9.00/4 (9122)
36a------------(40x) only 28 now Nichicon 12,000uF 50v (30mmX50mm) , sell only by 4 unit $12.00/4 (9124)all sold
37------------SOLD 2x PCM63 , 1x CS 8412 et 1x Tent , all for parts $35. (9132) SOLD
38------------3x new Salas SSLV 1.1 each are 2 regulators+ and
one (minus) all boards on pic $35. (9139)
39----------- 1x B1 micro board dual mono , my way to do it . $7.00 each and get lot (genuine , no scrap here) 2SK389 or LSK389 ($12. and $10.) if you need it .
40------------3x Shigaclone pcb (from Tibi here on diyaudio),with all not easy to find IC/transistors +drive 101N 16 pins each set $50. or better
all 3 set + extra set of rare chip (3) for $120. (3set boxed 850gr) (9071 -9077-9079-9074 sorry unable to get clear pic with this last one) all in text .
41------------25x Ero MKC 4uF 200v , 4pcs for $5.00 If you take them all , will ad on few other value same type free . (9054)
42------------3x CDM4/19 pcb without TDA1541; Quad 66/Philips 473 /Hafler ; $12.each with tranformer $15. For shipping pcb without transformer
less than 500gr , 1 without+ one with good for less 1kg , take them all ! just under 2kg (all weight with shipping box) ( 9142)
43-------------1x Arcam Delta power supply $25. (9144)
44-------------1x Arcam Delta (250??) display $35. (9145)
45-------------4x PHL 1280 8ohm in very good condition (list around $120 each) $240./4 (9109)
yy--------------lot more to come 😉
xx----------- https://www.diyaudio.com/community/threads/50-years-diy-must-reduce.409885/#post-7646369
  • Thank You
Reactions: pcjoe123
