Wanted: Schematic for vintage CJ SA Amp
Hello,
I have a vintage CJ Sonographe SA400 power amp, and am looking for a schematic to help me adjust the bias, the left heat sink is warmer than the right side.
If you have even a schematic for SA250? will help
Many thanks
That was the goal of my photo, a fairly simple amp in appearance
You need at least two “good” multimeters.
What we're missing are the original values and knowing which channel still has the right bias value (and if that's really the case) and knowing why one channel is hotter than the other and that's maybe that is the right question.
By the looks of it, these must be Bourns potentiometers which are of good quality, they seem to have been touched, does the amp seem original, intact ?
Have you tried sending an email to CJ ?
