For Sale Big Driver Clearance (project surplus)
Things you have for sale.
During lockdown I spent a lot of time and money building several speakers. Now I have many leftovers. Most have been used for only a few hours. Some never left their (unopened) boxes.
Happy to ship anywhere from the UK.
SPEAKER DRIVERS
18Sound 6ND14026-inch PA mid. Boxed. Ex-dem. £85
18Sound 10NMBA520110-inch PA mid/bass. Ex-dem.£165
Beyma 8BR40/N 8-ohm28-inch PAmid/bass driver. Boxed. As new.£35
Beyma 12BR70 8-ohm212-inch PA bass driver. Boxed. As new.£80
Ciare HW320 8-ohm212-inch PA bass driver. Boxed. As new.£75
Dayton Ultimax UM10-22110″ subwoofer driver. Boxed. New.£185
FaitalPro 3FE22 8-ohm23-inch full-range PA. Boxed. As new.£14
Faital Pro 3FE25 8-ohm43-inch full-range PA. Boxed. As new.£9
FaitalPro 4FE32 8-ohm24-inch full-range PA. Boxed. As new.£17
Faital Pro 5FE120 8-ohm45-inch PA mid. Boxed. Ex-dem.£18
FaitalPro 6FE200 4-ohm26-inch PA mid/bass. Ex-dem.£38
Faital Pro 8FE200 8-ohm28-inch PA mid. Boxed. Ex-dem.£26
Faital Pro 8PR200 8-ohm28-inch PA mid. Boxed. Ex-dem.£75
Faital 10FE200 8-ohm210-inch PA mid/bass. Boxed. As new.£32
Faital 15 PR400 4-ohm115-inch PA bass driver. Ex-dem.£145
FaitalPro 15 PR400 8-ohm215-inch PA bass driver. New stock.£165
6Planar tweeter. New stock.£23
GRS 12SW-4412-inch bass/sub driver. Boxed. Ex-dem.£35
HiVi A2S202″ full-range aluminium driver. New stock.£9
HiVi AS5B10100V 5″ full range driver. Boxed. New stock£6
HiVi B3N303″ full-range driver. Boxed. New stock.£13
HiVi D5.8A15″ mid/bass driver. New stock.£75
HiVi M3N93″ full-range driver. Boxed. New stock.£12
HiVi M5A85″ Magnesium midrange driver. Boxed. New stock.£39
HiVi M8A18″ Magnesium woofer. New stock.£55
Monacor SP382 PA115-inch PA bass driver. Boxed. Ex-dem.£95
MCM 53-108021″ soft-dome tweeter. Boxed. As new.£8
MCM 55-1240 8-ohm88-inch bass driver. Boxed. Ex-dem.£12
MCM 55-2970 8-ohm46.5-inch. Boxed. As new.£8
MCM 55-2971 8-ohm88-inch bass driver. Boxed.£8
MCM 55-2974 8-ohm215-inch woofer. Boxed. New stock.£26
MCM 55-2982 8-ohm412-inch woofer. Boxed. Ex-dem. Excellent cast-frame driver.£38
MCM 55-3231 8-ohm88-inch woofer. Boxed. As new.£12
MCM 55-3232 4-ohm410-inch woofer. Boxed. New£12
Peerless D27TG-35 6-ohm2Silk-dome tweeter. Boxed. As new.£28
Peerless KO100PLQ14″ mid/woofer for JBL Control 1. New stock.£16
Peerless 830669112-inch PA bass driver. Boxed. Ex-dem.£58
Peerless FSL-1830R09-08418-inch PA bass driver. Boxed. New£92
Purifi PTT6.5X26.5-inch Mid-woofer. One as new; one with small tear in surround (half price: £175). Both boxed.£349
SB Acoustics SB26STCN-C000-421″ soft-dome tweeter. Boxed. As new.£24
SB Acoustics 29BAC-C0042Beryllium Tweeter (4-ohm). Boxed. As new.£195
TangBand W5-214325-inch full range driver. Boxed. New/old stock£75
TangBand W8-180828-inch full-range driver. New stock.£295
Visaton BG17 8-ohm46.5-inch full range driver. Boxed. As new.£18
Visaton BG20 8-ohm28-inch full-range driver. Boxed. As new.£36
Visaton WS17E 8-ohm26.5-inch woofer. Boxed. As new.£24
Visaton WS25E 8-ohm210-inch woofer. Boxed. As new.£36
COMPRESSION DRIVERS & HORNS
18Sound XR1496C11.4″ Horn. Boxed. As new.£39
18Sound XT108611″ Horn. Boxed. As new.£49
Beyma CD10Fe/N21″ Compression driver. Boxed. As new.£45
Beyma TD19411″ Horn. Boxed. As new.£39
BMS 211911″ Horn. Boxed. As new.£39
BMS 455511.4″ Compression driver. Boxed. As new.£99
BMS 4540-821″ Compression driver. Boxed. As new.£79
Celestion CDX1-1742 18-ohm compression driver. Boxed. As new.£69
Eminence N314X-811.4″ Textreme Compression driver. Boxed. As new£159
Faital HF10AK-811″ Compression driver. Boxed. As new.£119
Faital STH10011″ Horn. Boxed. New stock.£19
MCM 55-132111″ Compression Driver. Boxed. As new.£12
P-Audio SC2 F1.411.4″ Compression Driver. Boxed. As new.£72
P-Audio PH-322011″ Horn. Boxed. As new.£16
P-Audio PH-8511″ Horn. Boxed. As new.£28
Peerless DFM-2544R00-08 11″ Compression Driver£49
RCF CD35011″ Compression Driver£59
RCF HF9411″ Horn£49
SB Acoustics HB22511″ Horn£12
