I see that in some of Trols' speaker designs, he lines the port with felt. I assume this creates an aperiodic port? Acts somewhere between the size of the original port and the new stuffed port?
I tried it on my 2-way floorstanding speakers, and I liked the result more than fully plugged ports (I rely on my sub for the really low stuff.
The two resonance peaks of a reflex enclosure would still be present, but the tuning would be subtly altered.
Increasing the port resistance further would result in the single, low amplitude resonance peak characteristic of an aperiodic enclosure.
There's more information in this recent thread: https://www.diyaudio.com/community/threads/a-question-about-port-bungs.408084/
It lowers the port output and tuning frequency. I use it sometimes, in the cases where port length does not fit in enclosure or it gets close to the wall.
Thank you. That is the case here. Both are less than 10 inches from the way, and the right speaker is boxed into a corner. Not ideal, but only setup that works for the space.It lowers the port output and tuning frequency. I use it sometimes, in the cases where port length does not fit in enclosure or it gets close to the wall.
Ah, ok. I will try again with the rolled up full stuffing. I am using the Frostking denim insulation. Easy to work with and pretty inexpensive.You need to fill the vent to push it aperiodic.
