For Sale DSP Headphone Amplifier
Things you have for sale.
For background, I'm a professional hardware design engineer with over a decade of electronics design experience.
I've been working for a couple months on this DSP headphone amplifier using the following major audio blocks:
  • DAC: AK4493S
  • Amp: OPA1622
  • ADC: AK5572
  • DSP: ADAU1467
Audio quality measurements are quite close to the DAC/ADC chip specifications, actually the chip specs are beyond the capability of the audio test equipment I currently have access to (Prism dScope III).
I have two extra units from my prototype build available, would be happy to provide at cost ($375 shipped to USA). The GUI design is still very much a work in progress (using LVGL & SquareLine Studio), so buyer definitely would be able provide some input to that. Firmware updates are very easy with computer + WiFi connection to the unit.
Some additional details:
Output Ports:
  • 1/4" headphone jack (32ohm to 600ohm)
  • toslink digital output
Input Ports:
  • analog line input (initial prototypes use an included 3.5mm adapter cable)
  • toslink digital input
  • usb input (initial prototypes use an included USB adapter board)
Power Management:
  • 120VAC wall power input
  • On-board linear transformer
  • All analog power supplies are linear with extremely high PSRR
Digital Signal Processor:
  • DSP has capability for many bands of parametric EQ, psycho-acoustic bass, mono-summing, etc.
  • There is also room for many more DSP algorithms in future - current DSP utilization is less than 10%
