Hello,
I can access places like Element14 (Newark USA, and known as Farnell in UK) or Digikey.
The tweeter as you can see has a fine tape - more to maybe hold the copper dome down. The woofer the foam has long gone, or never was used. The speakers are Celestion SL-6. I fixed the corrosion issue in another thread back in December, with Rust Oleumn 5in1 paint
https://au.element14.com/pro-power/hsht-roll-0-8x25mmx5m/tape-pe-foam-5m-x-25mm/dp/7224825
tweeter and maybe woofer
for the woofer maybe
https://au.element14.com/multicomp-pro/ppc116/sealing-tape-pvc-25m-x-6mm/dp/176068601
Home Depot or the equivalent. Close celled neoprene weatherstripping (draught exclusion tape)
dave
dave
I use gasket tape from WES trade or Wagner retail and used to buy a 25m roll. Unlike the weather strips like Raven from Bunnings etc it doesn't fall apart after a period of time and allows easy release of the driver for removal. For tweeters I use the thin white closed cell sheets that wrapped on electronic components.
https://www.wagneronline.com.au/tape/service-products/tools-test/gt7100-6814/6851/pd/
Thanks Dave, that is the sort of thing at Element14, though geared for audio etc, still weather resistant in the notes, I googled what you mentioned it looks good also, so will try to locate a source locally,Home Depot or the equivalent. Close celled neoprene weatherstripping (draught exclusion tape)
dave
@rabbitz
Thanks Rabbitz, I would not go to bunnings, Element14, i assume their products might be better. Wes product looks good. I was really needing adhesvie one side so the woofer could be removed it needed.
