Sony KSS151A Loop Current Laser Current
I have a question about the KSS151A loop current. White sticker there are different loop currents printed on it. From (45mA to 65.8mA) If the laser pick-up is defective, can you install all of them with different currents? If I have 47mA original can I install a 65.8mA laser pick up?
Gruss Chris
Can I install a 65.8mA laser pick up? Yes, of course.
Laser power supply can deliver until 110mA or more. More power current does not have sense, because the laser diode is worn out.
Laser current label is a measure made at factory, it depends of multiple factors, as ambient temperature, time playing, laser power potentiometer age drifting. It's a orientative data, but not an absolute data. I'm sure this value could change in factory when it was made in a few minutes later.
