200mA capability , insane bandwidh / thd . this will make amazing headphone amps, kinda overkill . Most be pretty expensive.
But in the datasheet it suggests to add a output resistor with Cload > 10pF.
Guess that'll be a concern for headphone cable and driver itself.
It's capacitive load drive might dictate it's capabilities as a DAC I/V too.
The 1611 is the gold standard because of its decent output drive and the ability not to fall to bits, with gross distortion, with the typical feedback cap in parallel with the resistor.
The flagship modern DACs are crying out for an opamp that can drive more current but it counts for naught if the distortion is awful because of capacitive load. Not to mention if it's unstable.
It's also double the quiescent of the 1611 and has the knee in its voltage noise much higher in frequency. If you don't need the output current the 1611 seems like a better choice still as they will both have negligible distortion.
Looks like Mouser got some in stock. I wonder how they sound.
High slew rate 105V/us!!
Will it make it prone to oscillation?
Input bias current on the high side due to the bipolar LTP. I like the ~80db loop gain at 20KHz. You need to be very careful with the layout and make sure you have >200MHz scope handy when you test to check for oscillation.
Sound? The specs say they sound like they are not even there.
- Design & Build
- Parts
- A new OPA891
