Marantz Pm-Ki Ruby Amplifier Upgrade SMPS600 to SMPS1200 Is this possible!
Hi all.
Marantz Pm ki Ruby Amplifier
Does anyone have any thoughts on upgrading the Hypex smps600 to Hypex smps1200 !
I believe this being same setup also in the pm12se and also Model30 Amps.
The problem is that the NC500 module draws up to 700W in 4 ohms each, that is 1.400W for the pair, and the Ruby,Pm12se and also Model 30 power supply is 600W only.
If this was a possible upgrade would this be a plug and play
Any thoughts appreciated.
