Search Conversations
As long as we're here, is there no action to remove/delete them? Thanks.
Ah ha, If you use the "Filters" pull down menu you can select either "Started by..." or "Received by..." and type in the members name.
Don't put an "@" in front of the members name.
As far as I can tell you can't search by keyword.
When you search conversations for a key word, and you have a list of results, when you click on the result- does it take to the point in the conversation where that word was used?
For me, it just takes me to the last page of that conversation.... what am I doing wrong?
