Hello,
Because of an upgrade from a 2TD, I have 2 crossovers and 2 LD25K drivers from CSS. Rather than the MTM, I was thinking of buying two midwoofers (LDW7) and building a ported bookshelf speaker (one midwoofer, one tweeter each). I have built a couple of speakers from kits but have no idea about designing an enclosure. In looking around I found the speaker box enclosure calculator on this site, entered the Vas, Fs, Qts and it spit out .9 cubic feet with a 7 inch long 2 inch port. My newbie ask is if there is advice about dimensions and locations in order to put all three holes (2 drivers and port) on the front. Thanks.
I found information on your chosen driver, which may be helpful: https://www.parts-express.com/CSS-LDW7-7-Midwoofer-290-3002?quantity=1
If the port pipe is to be front mounted then make sure it is shorter than the internal enclosure depth by 2 or 3 inches.
If that makes the internal volume too large when combined with the height and breadth dimensions you require to accommodate all three openings, you can construct an L-shaped port with the help of a right angled pipe coupler. The effective length of an L-shaped port is the distance through its centre.
Other than that, I would arrange the three openings vertically in line, with the tweeter as close as possible to the midwoofer, and the port opening at least 3 inches away from the midwoofer.
If you require any additional help, please furnish more detail.
P.S. A quick calculation shows that an enclosure of internal dimensions 18" (h) x 10" (w) x 9" (d) would give an internal volume of 0.94 cu ft, thus providing some necessary over volume to allow for the space taken up by the drivers themselves. However, that's simply a "starter for ten" to head you off in the right direction. Some tweaking may be in order!
