Amp appears to be working but no audio. I'm getting waves every where they should be. Just no audio.
Nevermind. I figured it out. One of the tl072's was bad. I can't begin to tell u how much time having a thermal camera saves! It's just as valuable as a scope in my opinion.
It's normal for the transistors to heat up. The solder mask around Q201 often darkens from the heating.
I don't remember R204 heating that much. Confirm that D201 is within tolerance.
