(Due to weight – local DC/MD/VA Metro Area only).
Available for sale is the North Creek Audio Echo Speakers system– 3.1 speakers (LCR + free sub).
The cabinet construction was overkill, all Baltic Birch plywood with 1.5” baffle. They are finished in beautiful teak veneer with three coats of Waterlox tung-oil finish.
They were lightly used in a bedroom system, never pushed hard. I had designed the Left/Right to be wall-mounted (using a recessed French cleat system) – but they work just as well on speaker stands. T
hey are sealed speakers and are meant to be used with subwoofer. I can include a passive mini-subwoofer to go with these (built using the Tang Bank W5-1138MF - basically Voxel subwoofer) – also finished in teak veneer.
They are 10/10 in both functional and physical condition. Also included in the sale are a spare pair (2) woofers (just in case you ever damage them and need a replacement).
I’ve included horizontal polar measurements from 0-80. This measurement was at 1 meter, response further away was even more smoother.
So you are essentially getting:
8 – North 13W-06S woofers
3 – North D25-06S Silk Dome Tweeter
1 - Tang Band W5-1138MF woofer
Everything enclosed in beautiful teak Baltic Birch cabinets.
I don’t know what to ask, but I was thinking maybe $250?
Hello Dkalsi. I'm sorry if my question doesn't relate to your selling. I've received a set of custom-built North Creek Music CM 7 speakers with a KG 5230 subwoofer. I'm researching how to set this up. If it's possible, can you provide me with some guidance/tips? Which receiver should I use, what is ohm impedance, etc.? I'm looking forward to receiving your response.
