Greetings all )
So I imported this Mitsubishi Jeagam back in 2004 from Japan or China, I'm not sure anymore, and then I stripped it.
This is what a complete one looks like, pretty..... actually its hard to find an image of one becuse they were only sold in Japan.
I was clueless in 2004 and I'm only slightly less clueless now about loudspeaker parameters, so I need help choosing a 6.5 inch speaker for this please. I'm hoping for a speaker around 90 - 92db becuse my tweeters are 89db Morel MDT-12
I'm using a wondom Jab4 amplifier and that will serve as a crossover.
What 17cm - 6.5" woofers would do well in such a small space please? I measured the internal volume as 14.7 litres.
I'm not expecting miracles, just something with reasonable bass.
I will fibreglass the interior of the box to make it more rigid, like I did on the one below, and rebuild the face so it looks stock. Will be sweet.
You have to put two "cups" behind each lateral speaker. The internal volume will suffer from this move but isolation of the membrane of the lateral speakers from woofer's cone is fundamental.
You mean i need to isolate the tweeters from the woofer? Okay
Its funny to think about how these radios were built - barely any internal volume becuse the electronis were so big
Uhm, tweeters...I was to ask.
Usually you need to have the two channels with full band capability. In case, a subwoofer is added. But having two tweeters( and each will be HPed at about 2kHz), leaves you with most part of the content reproduced by the single woofer. Since your Wondom has 4 channels I don't see the limitation to the single woofer. Oh yes, the Jeagram 8200 allows for that...
