After a long discussion.. WE have decided last night to offer Mono Block/Power Amp in Fall 2024
I will offer two types of Push Pull amp (Mono Block / Power Amp based on KT170 ( can use other KT tubes))
It is a Push Pull amp. The power is 40~50W per Channel
PCB KIt:
It is a 50W per block with KT170/KT tubes. OPT :TBA
Once I have more info I will post in here..
GOOD and Affordable ....Made in Japan...
PCB KIt:
I'd be interested Viktor, it sounds a good idea
If it's PP that would make balanced / differential input easier no? I'd welcome an input / option for that
I'd lean towards no volume pot too
I would be interested in the premium version Victor.
Would be interesting to compare sound quality and characteristics to TU8600SVK.
Would want it without a volume pot, and options for balanced & RCA inputs if possible.
For sure it is not another TU-8600S. The mono block will have 50-60W output per channel
Please stay tuned
Please stay tuned
Are you looking at it achieving a similar sound quality level of the 300B but with more power and the sound characteristics of the KT170 tubes.
300B is only 8~9W. KT170 is more powerful. The sound of KT170 is completely different from 300B.
Excellent news. I would 'vote' for no volume pot. I would also love to have an option to have a balanced input (?transformer based) - purely for the convenience of long cable runs (required in my current setup). Great idea to offer a point to point version as well as a PCB version, that will make it easier for those who do not wish to do P2P. It would also be nice to have an option to have upgraded resistors (AN tantalum) in the signal path.After a long discussion.. WE have decided last night to offer Mono Block/Power Amp in Fall 2024
There are two versions.
Point to Point with Hashimoto and PCB + premium OPT.
Point to Point Power Amp:
MR Ohashi will do the experience soon.. (1) Can the Hashimoto transformer HW 40-5 be mounted on SV-P1616D?
(2) What are the electrical characteristics?..
PCB KIt:
It is a 50W per block with KT170. OPT :TBA
This mostly depends on how the bias is set. Class A push-pull with this tube starts from about 35 Watts per channel, and you can go up to >200 Watts in Class AB, but that does not come for free.
Hi Victor -
This looks like an interesting project. I like monoblocks.
Things I look for:
Bruce
Things I look for:
- Best quality output transformers.
- Room for best quality capacitors in the layout.
- Manual bias setting for output tubes. (I know your electronic automatic bias setting is well done, but I miss manual bias. It's simple circuit-wise, easy to do, allows for tube rolling without limiting the output power of different tubes, and you know what is happening.)
- No volume control. That's the preamp's job.
- Don't care about resistors. (Don't really think they make much of a difference in sound compared to tubes, signal capacitors, and output transformers.)
- Don't care about point-to-point wiring vs well-done heavy-duty circuit board. Circuit board can assure wiring follows proper paths if well layed out.
Bruce
1. No volume pot
2. Ultra-fast avalanche sinter glass diodes for rectification. (Using these in my tube amps projects has made me forget about tube diodes). Smooth upper registers, deep soundstage and incredible bottom end performance. The best part is they are very inexpensive and no more expensive rectifiers that eventually fail.
the sample opt has just arrvived Japan for Testing... LL3733 is a custom made OPT for the momo block
