SOLD
The switch is an Elma four-wafer. Resistors are Susumu thin film 0805 SMD 0.5% 25PPM. The switch wafers are made for through-hole resistors, but SMD resistors have been soldered across the circular pads. Solder is Cardas quad eutectic. The audio taper is taken from a resistor list to be found on the Goldpoint website. Included is a spare resistor of each value.
Please note that the switch bushing is of the new kind. It has two flats and is intended to be inserted into an appropriate panel opening to prevent the device from rotating. There isn’t the familiar tag that slots into a hole in the panel as in older types. But it is easily clamped using toothed washers. Coupling included. Eyelets are unsoldered.
€80 incl. postage to UK and EU only.
PayPal preferred.
SOLD
PayPal preferred.
SOLD
