USB Sniffer (protocol analyzer) using Wireshark
While troubleshooting a USB device I came across a low cost USB Sniffer (protocol analyser) which uses Wireshark Capture program.
I want to share with the community.
I myself built two units which work like a charm. The soldering is a bit challenging because of high density SMD part population on the PCB but it is possible to hand solder everything. I ordered the PCB from JLCPCB and parts from mouser and LCSC (China). All parts are readily available and all software/firmware is available free of charge (incl. sources!).
I want to thank again Alex who made this available for free. Professional USB protocol analyzer are costing thousands of $.
Links:
GitHub project: https://github.com/ataradov/usb-sniffer
A video of building a unit, very helpful: https://www.downtowndougbrown.com/2023/08/building-alex-taradovs-open-source-usb-sniffer/
Hackaday article: https://hackaday.com/2023/06/13/cheap-usb-sniffer-has-wireshark-interface/
Hardware obsolete: https://github.com/ataradov/usb-sniffer/issues/7
Also read the discussions in GitHub since it contains some value information about obsolete parts and building the software from the sources (incl. executable for MacOS)
Low level protocol analysis, like the ADDRESS REQUEST. This is not possible via usbpcap. Also with the unit you are setting up a man-in-the-middle scenario full transparent capture an USB stream of a separate device which can be a play console or any other USB supporting device like a smart TV, where you can’t use wireshark on the target. Host and target can be separate devices, like host a Linux/MacOS/Windows PC with wireshark capture and the target a smart TV or play console with a Joystick.
The usefulness over sole wireshark depends on the scenario. If you’re troubleshooting firmware issues of USB gadgets it’s a must. If you haven’t come across limitations in your scenarios you’ll probably won’t need it…
Reactions: bohrok2610
IMO this sniffer would be useful for capturing Android and iOS USB hosts too. Eventhough android runs linux kernel, it may be easier to build this HW sniffer than building a custom kernel with the usbmon module for an Android device, especially if not rooted.
Reactions: tubekiddo
Absolutely, because of the specific man-in-the-middle approach it’s useful to observe USB traffic upto HS (High Speed) on any target, no matter of the operating system of the target, even a Smart watch running Tizen OS (or a PS or XBOX).
