Hello
I have two Melos SE75 mono blocks which have bad output tube sockets. I always had to clean, tighten pins, squeeze tubes to get good contact. I'm really tired so I want to change the 8 sockets with the BEST. There's a lot of Chinese sockets but... I found these which look great with thick metal pins. I need PCB sockets but I can fit std sockets with fiddling.
https://retrostore.eu/en/d/patica-elektronky-9-pin-magnoval-b9d-do-dps-1000559/
Any recommendations ?
The ones you've found look OK.
This is a supplier I use from time to time; https://www.langrex.co.uk/products/b9d-magnoval-ceramic-pcb-valve-tube-sockets-x2pcs/
