Rewiring Bespoke / Proprietary Systems?
I admit that I'm proud to be a scrap merchant. I got a home-theatre active subwoofer. I only wanted the driver. But the sub box contains all the gubbins. As usual there is a multi-pin cable connecting the (failed) head unit to the system.
I really don't want to throw away a 5.1 plate amp that claims: 120w + 80w x 5. ( I know it doesn't) but that's respectable grunt for a home theatre system. Can I rewire the board input to accept simple stereo phonos and an on/off switch?
Schematics are here: Service Manual
It looks like you only need a breakout cable to split the proprietary minidin input connector into the individual channels, and the trigger to turn the power supply on. Of course you also need an external volume control/preamp.
