Tamura Iron, Sakuma Phono
Selling some Tamura items from my collection in excellent to new condition:
1x pair TKS-27 step-up transformers: 0-150-200-300 : 100k 450€/pair
1x pair A-4714 output transformers: This is a very interesting one, as it can be used as line output or speaker output. Primary 5k, 60ma / Sec. 600ohm CT, 6ohm. 650€/pair
1x pair A-342 interstage transformers : 5K:5KCT, 30ma 450€/pair
1x pair A-394 chokes: 30H, 40ma (NIB) : 375€/pair
1x stereo set parts for Sakuma phono EQ: 2x VL207 variable inductors (0.5H-5H,7ma), 2x 0,033uf Duelund Cu-Sn, 2x 0,047uf Duelund Cu-Sn, Kiwame 10k, 3k x2. Resistors and capacitors are new and unused. Have a new pair of Duelund Cu-Sn 0,47uF to finish off the EQ module if needed (depending on which Sakuma phono schematic you want to build). 250€ for the set
Will consider offers and discounts for multiple items
Items are in Belgium, will ship worldwide
