Need help finding info for transistor
I'm new here at diyAudio and I'm playing around building audio circuits I need help finding some info on this transistor.
Thanks in Advance Aaron
Often those house numbers are selected for hFE range (like the letter grades on the Jap parts) so the manufacturer can better match, or if they want the top of the range. Sometimes they are selected for voltage, such as 2N3773’s that will run at 200V (Peavey’s SJ6343). The problem with all this is that any such testing is done under NDA, and they do honor those agreements which means WE can’t get at the data. Stuff like Peavey and early Crown got out because both were very free with their service info and PUBILISHED their cross references.
Usually you just have to figure out what the circuit needs and use an appropriate part. Fortunately today if you run into an unknown TO-3 most of what ON offers is miles ahead of the original, even if the selection is limited to 2 or 3 parts.
The semiconductor is a Motorola TO3 is a “House Number”. By the code date (1980 7 week), I would suspect a NPN 2N3055. @ BGW I used many standard parts with special selected parameters. Some were Beta selection, Beta graded, Vceo & other. If you have the schematic a good EE should be able to cross reference a part.
Duke
Well got two of the transistors out and there is one leg on each of them that spins I don't think the legs suppose to do that maybe the next two will be better I'm learning at them moment and having fun making little things and seeing them work really Hugo thanks for the help I been a slow learner all my life still don't really know how a transistor works
Reactions: Netlist
Ya my friend that I got it off of thought he could repair it himself I told him if he had left it alone I might have been able to do something with it. While I wait to see what he is gonna do I'm trying to make a Bluetooth speaker for a person using this chip TA8210AH like I said I'm still learning so learning everything I can about it first before I start making a circuit
