Sold
Transcendent Sound Masterpiece 300B preamp. Comes with a set of tubes that have around 100 hours on them. I used it in a secondary system that has moved to a home theater setup. The preamp sounds good to my ears. There is a slight hum that I can only notice if I turn off whatever is playing and put my ear 1-2" from the speakers (~88 db efficient). It never bothered me enough to chase it down.
Asking sold plus actual shipping charges
Ships in a box that is 21" x 18" x 13" from 54956
I am not sure what the differences are between the versions. This one is about two-three years old if that helps.
That should put it after the revision. I'll do a little research to see if I can pin it down. I'm only interested in the current production.
