For Sale US: PAIR each of miniDSP 2x4 balanced v1.4 and miniDIGI v1.2
Things you have for sale.
* SOLD *
I am going through a lot of stuff and taking old projects apart while I prep for a big move, and I found these gems!
PAIR of miniDSP 2x4 balanced kit v1.4​
PAIR of v1.4 and miniDIGI v1.2​
connectors for stacking the boards so they can be used together​
These boards stack and give you four switchable input SPDIF channels, an ASRC, and a 4-ch DSP engine with four balanced output. You get 8 channels in total, divided into two independent 4-channel stacks. Awesome for a 4-way speaker project with digital input! The outputs can be used either in balanced or unbalanced mode. You can also use the balanced analog inputs if you desire.
More info see:
https://www.minidsp.com/images/documents/Product Brief-MiniDIGI.pdf
https://www.minidsp.com/images/documents/miniDSP 2x4 Balanced and Kit - User Manual.pdf
