Hello everybody! can you help with the manual on pse studio two? One channel burned out in the amplifier. I would be very grateful.
Did you see this thread? They talk about PSE Studio II... a few posters tried to draw the circuit diagram(s)...
https://audiokarma.org/forums/index...read-professional-systems-engineering.898230/
Thank you very much, I will try to register, without this the schemes are not visible. Admin approval is not clear how long to wait. Or maybe there is just the PDF of the device itself ?
Thank you so much Extreme_boku! It's like Fort Knox, not a museum amplifier. 🙂 I will draw a diagram with my own hands , the pse bird is small
No worries... draw a digram and then post it here... we could at least attempt to guide you in the right direction. Good luck.
- Repair audio
