First post.. thanks in advance for any help.
I have a Memphis mcd1500 that had blown up or at least had some bad Ird3205.. I sourced them Nos from out of country .. and replaced all of them and all the ird 640 also the irf 9640 .. the amplifier will power on now no protection light comes on but it isnt receiving a drive signal from the board... I believe it to be the chips are blown but Memphis has sanded off the part numbers .. or if any of y'all could think up something different it may be let me know .. I'd appreciate it ..
I removed all the amp section MOSFETs and rechecked but I have no drive signal ..
Any idea what the part numbers are in the ic chips??
That's a low frequency but shouldn't stop the drive from being produced.
What's the input signal on pin 4 of the LM361?
Set the scope to DC coupling2v/div and 5us/div.
Are you sure that you were on pin 5 of the MC14060 previously?
Is your scope grounded to the negative terminal of the 12v power supply supplying power to the amp?
No. Pin 5 is directly below that in the photo. Look up the datasheets for the ICs for the pin numbering scheme.
What's the DC voltage on pins 4 and 3 of the LM361?
What are the signals on pins 9 and 11 of the LM361?
Are the output FETs in the amp or out of the amp?
Solder a bridge between pins 13 and 14 of the TL074 on the driver board. Does the DC voltage on pins 3 and 4 go to about 0v DC?
Pins 3 and 4 stay in a negative dc voltage .. I'll solder a bridge on pins 13 and 14 shortly and report back .. thanks
Both are at 6 volts.. I soldered the bridge but still no drive signal to where the fets go in the board .. thanks
- General Interest
- Car Audio
- Memphis 16-MCD1500 repair help
