Someone must've maxed out on it ..lol new to amp repairs looking for any info I can get I appreciate it white dragon.
Traces were damaged
so needs cleaning to see the top.
Bottom damage is fixable with bridges.
possible numerous end of life electrolytic
then yes find original fault.
do able depending on top trace damage.
and finding fault.
and finding fault.
These old Orions have a problem with leaking electrolyte. It likely saturated the board and conducted between layers. I'm no fan of blindly replacing electrolytic caps but these caps, at this age often need to be replaced throughout the amp.
You will need to remove the cap and 100% of the contaminated/carbonized fiberglass.
For all electrolytic caps that you replace, you need to use acetone and cotton swabs and a toothbrush to remove the electrolyte before replacing the caps.
- General Interest
- Car Audio
- Orion 225 2nd gen amp burnt how do i identify this burnt board piece?
