Hello, i wish to build a 3way loudspeaker using a 12db crossover and two bass drivers wired in parallel, but im having trouble understanding how to wire the impedance compensation, wich of both images is the correct way to wire them?
The speakers are the same model btw
Also when wiring them in the crossover i just need to put the filter behind the notch filter right?
First method( i belive this is the right way)
Second method
thanks for the info!
What about wiring them in a crossover? Can i just wire them as if they were just one?
