Suggestions for a big-driver 3-way
Hello!
I need suggestions for 3 or 4-way designs with the following criterion.
  1. 3 or 4 way
  2. Pro Drivers
  3. Sensitivity 95dB +
  4. Minimum of 15" driving the bottom end.
  5. Horn-loaded CD
For now, I have found these two designs, Troles TL-1 or 2 and the KS-1804 mk2, (I'm unsure if the horns are still available). Any other suggestions/options to consider?
Crossovers for TL-1 or 2, cost $2000+, which also includes some allied items to build his speakers. For that amount, I could get a miniDSP Flex Eight and a 6-channel amplifier, provided the active DSP route is plausible.
  1. How easy or difficult would it be to make Troels' TL design active?
  2. If I go the active route, I assume I can play around with the drivers a bit, that is, replace the expensive 18" BMS 18N862 with the Faital Pro 18FH510 or even the BMS 18N840. Is this possible?
Appreciate your suggestions/feedback, please point me in the right direction. Thanks! 🙂
