Technics SL-PG440A
So around the dac on the digital supply line I'm assuming this is a candidate to be changed to an Oscon cap?
I would start from sorting out the analogue output stage before doing anything with the digital part. Otherwise you would probably not hear any improvements.
Would you mind posting some photos of the main board - both from top and below?
Some photos of a 770D (yes, dual dac but general layout is pretty similar) mod from ca half a dozen years ago.
The change was audible...
I found my old PG440 at my mother’s place.
It had problems skipping forward randomly. It turned out to be a common problem in the CDM-module. A capacitor usually dries out.
Now it plays like a champ and it is really fast detecting the cd and changing tracks.
Now I have ordered parts to add toslink. Thanks for the tip @Andersonix
I hope the parts from mouser arrive to the Christmas break 🙂
Reactions: Andersonix
